SOLVED: Transfer case end spraying fluid on undercarriage?
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
Hey there. 1990 Bii project trying to get to body restore but I'm having 4x4 and apparently transfer case end issue.
If you check the attached photo, it appears that I have a leak at what I assume is the rubber piece and it's spraying my undercarriage something fierce.
Any idea what the part is that I need to fix this thing up?
Thank you to anyone and everyone for any information!
And please check my recent 4x4 post out if you have any idea on 4hi not engaging hubs and 4 lo doing it with ease. This would wrap all my threads up!!! Thank You all!!!
dvdswan
2,896
Seattle, WA
Ranger XLT 2WD
That looks like a grease boot for the driveline. With the grease spinning out you will need a new boot.
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
You wouldnt regret swapping that out for a universal joint shaft.
I'll do it! Do you know a part number or comparable so I can get an idea of what to order? I'm having a hard time finding a boot
ford4wd08
510
Alcoa, TN
2.8 V6
Rock Auto had replacement shafts. I would check there.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Also jeffs bronco graveyard.
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
ford4wd08
510
Alcoa, TN
2.8 V6
You need a flange to flange driveshaft. They have been making replacement shafts for your style for a while now.
Measure your current one, as long as the length is the same the one you linked will work.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I bought mine from Jeffs I think, cant remeber. I took out the cv shaft and put the u-joint one in in about 10 minutes.
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
I
I bought mine from Jeffs I think, cant remeber. I took out the cv shaft and put the u-joint one in in about 10 minutes.View attachment 73320
I Have mine on order! Should be here Friday or Saturday! Will update after install. I think this was causing my shutter/rear end vibration when I would step on the gas to get up to speed quickly or to power up a hill from a standstill. Fingers crossed.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I
Oh yeah, mu cv shaft shuttered under load. New shaft worked wonders. Plus consider that every busing in that truck probably shot. Leaf spring bushings, sway bar bushings, bidy mounts, etc.
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
Hey I got my new Rear driveshaft! I'm having trouble removing the bolts with a breaker. I've put a lot of force on them. I have it battery negative disconnected, lifted and in neutral(haynes) but I cannot break those bolts loose. I sprayed them with PB blaster and will come back and crank them again. However I am having a good amount of play in the shaft when I try to remove the bolts. Any idea how to break em loose?
Should I try to break them loose while it's still on the ground and in park so I have less play in the shaft or will that even make much of a difference?
And I'll definitely get on the bushings! It's noisy so I'll do those and the shocks and coil springs hopefully soon. Hopefully my leafs are good.
Thank You for the information!! I truly appreciate every bit of it
ford4wd08
510
Alcoa, TN
2.8 V6
Leave it in park to keep the shaft fixed.
Also heat is your friend. You are fighting factory lock tite on those bolts.
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
I'm thinking i need to bust out the torch.. must have some loctite holding them
A4LD_Nghtme
47
Twin Bridges, CA
Bronco II XLT 4
That's is exactly what I thought! Thank You so much. I just posted about heat too at the exact same time haha!
Kirby N.
March Truck of The Month
