- Jan 16, 2020
- 50
- Ohio
- BII, Rangers
- 2WD / 4WD
- 4WD
Hi guys. I have an '86 BII with the FM145 and BW 1350 tcase. The truck was originally an automatic but the previous owner swapped it with the FM145 but never finished the linkage for the manual shifter. I'm having a hard time find the last lever off the BW1350 to make it work right. Also the current trans whines really loud in 3/5 and of course the ole FM145 supper sloppy shifter. No sure if the whine is normal.
However I found an '88 BII with what looks to be the mazada trans and manual floor shift on the 4x4.
Do you guys think its worth a $500 parts truck to swap in the mazda trans? Plus I would have all the correct linkage to make the floor shift work. Does anyone have any idea what I would need to modify on the '86 to make the '88 trans/tcase work?
Another thought, '89 was the first year for the D35 in front, correct?
