pat julian
- Feb 15, 2014
- 1
- Ford
- Engine Size
- 2.3
Planning on changing the trans fluid in a few days in my '93 2.3 five speed Ranger...Engine and trans have a little of 450,000 miles on them with no apparent issues..Fluid was changed roughly 100K ago at a Valvoline oil change shop...Research seems to show MERCON s the proper fluid...not MERCON-V...Is this correct ?? Also is there something better than standard MERCON that will make the trans shift smoother ?? Doesn't grind, or make noise..just doesn't shift "butter smooth" like other gearbox's I've driven...Clutch fluid is fine...Would just like to find something to make shifting less "notchy"...Had a '96 Ranger several years ago ...same drive train...shifted the same way...so I surmised it's just a "FORD" THINg.....Thanks...pj
