Tranny issue
Steverino
Portland, OR
I have a problem with my 2000 4.0 auto Ranger, 83,000 miles. From a standing start, the first shift into second gear is a "harsh slam." Before I take it in to a shop, I'd be interested in what this might be, and what to expect in repairs. Thanks very much!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
First thing is always to check fluid level and condition.
They are kinda known to have a little clunk. Mine clunks into second if you hit the gas hard, always been like that. :rolleyes:
Steverino
Portland, OR
I've searched my service records and found that in 2004 with 28K miles, this happened and they removed the drive shaft, lubed the yoke and installed a new boot. Could be deja vu all over again.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Do you have a one or two piece driveshaft?
Eddo Rogue
2,499
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
sounds like a sticky valve. There are many additives out there to address this. Also fresh fluid and filter may help.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Is your overdrive light flashing?
Steverino
Portland, OR
Auto trans so no overdrive light, right?
Transman304
43
Morgantown WV
Chrysler PT
2.4
If it’s a automatic it has a OD button on the end of the shifter.
Steverino
Portland, OR
Ah, yes forgot about that button--no, there is no overdrive light on. Thank you!
Steverino
Portland, OR
I have had my Ranger in to the Ford dealer service for this grans problem. (All the independent shops here seem to be scheduled far into the future.) I've been a customer at this Ford dealership for 30 years, it's service department has a very good reputation. The news was not good. They say it needs a new transmission, a rebuilt installed would be $5,500. That's about what the truck is worth in good running condition. The computer showed an error code "Line D , PO733" which means internal transmission failure. Also, one of you asked if the OD light was flashing. It wasn't but now it is. If I turn the OD off, the light stops flashing. I hate to give up the truck with only 84K on it. plus it would be hard to find a replacement that has the heavy duty rear end of this one. Another complication it that it has a very expensive engine repair issue; I could be in for more than $10K total, engine and trans. I had the trans flushed hoping this would do it, and my thought now is to drive it until it fails and then sell for salvage. Any thoughts?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Just throw a used engine and trans in from a wrecked truck.
Steverino
Portland, OR
That's one possibility. Service advisor told me that head problems are not unusual among Ranger engines.
Steverino
Portland, OR
Thanks to all of you for your thoughts and help! I did find a good trans shop which overhauled my trans for $1,700, all new parts included. So, I'm happy with this; got a nice smooth transmission again that should be good for the long haul. The engine problem seems to have "solved itself" after bringing the coolant back to normal. I failed to mention that this truck just mostly sits, very low mileage these days, i.e., 1,000 miles per year. I have to make sure I use it more. I also have a '52 F-1 which I restored, and the head gaskets will leak if I don't drive it regularly.
MikeG
752
central Texas
B4000
2"
235/75r15
I don't know about that code, but shifts and everything else are controlled by the flow through the valve body. Sounds like a pretty BS answer to me.... WHAT is not working in the transmission? WHAT EXACTLY? If they can't answer that, they are just throwing YOUR money at the problem.
Look into getting a 'crate' transmission. Should be WAY less money. When I had my 5r55e rebuilt, that was an option, but I found a transmission mechanic that wasn't crooked and got it rebuilt for about what a crate transmission would have cost.
The harsh shifts are very likely caused by a solenoid sticking, or some port in the valve body sticking. You can buy rebuilt valve bodies and put one in yourself (I did this when my truck stopped shifting at all) and it got me a few more years, but the rebuilt valve body had some very harsh shifts unless I was pretty well standing on the throttle. Eventually the transmission mechanic got that sorted out as well and I wouldn't endorse the place I got the rebuilt valve body from, so you are on your own there. It isn't a difficult job to change out, just messy. At least on my truck.
Have a difficult time believing the transmission is toast at that mileage unless it was horribly abused. Drop the pan and see if there are chunks of anything in the bottom of it.
Whoops - just saw the update. Good for you! Did they ever say what was wrong with it?
Good luck.
