Tractors
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Been neglecting (not using) this truck for a while so what's better way to charge the battery back up
I have a 2008 Ford Explorer with the 4.6L V8 in it, and been thinking about getting an older F150 late 90's to 2008-10 to use to tow my 18 foot car trailer when I need to haul my tractor and implements around. Does your F150 have any issues pulling your setup? Your JD is bigger than my BX2680 so if you don't have any trouble with your setup the F150 would be fine with my smaller tractor/trailer.
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
I would think you would be fine towing that with your explorer. Especially if it’s only a couple times a year.
I have a 18’ trailer I tow occasionally tow with my ranger. About 2k lbs of trailer plus 2k of tractor is no problem.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
The Hudson trailer I have was lengthened 2' when I ordered it and it seems they didn't add it and adjust axle position. All in all it fish tails a lot because they didn't move the axle position back... With the right trailer it would be 100% fine. But I had to choke the tractor up on the trailer to prevent the fish tailing. Also I think these trucks need about .5% lower reduction on each gear 1st and reverse are way too low of a ratio and cause a lot of foot work. Just my opinion of the trans...
85_Ranger4x4
17,817
SW Iowa
Mom's old irs explorer ate rear struts and rear sealed wheel bearings just doing explorer crap. Never touched a trailer or hauled anything of note.
I wouldn't tow a half empty kleenex box with one.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
So, I tried looking up about the Ferguson tractors and comparing the pictures to try and determine exactly what I got and I’m confused. It’s got an early grill, but seems like a mis-mash of everything else. Probably going tomorrow to retrieve it and I’ll try and see if I can work out better identification. Never run one of these so I hope I can puzzle out how to run this beast. Anyone on here know much about these? Anything I should know about starting/running it? Supposed to be part of the 8N/9N/etc tractors. Got a 5’ brush hog and a 7’ blade for $143 each too.
https://bid.hostetterauctioneers.com/lot-details/index/catalog/33587/lot/5311594?url=/auctions/catalog/id/33587
85_Ranger4x4
17,817
SW Iowa
Henry Ford and Harry Ferguson had it out so they split up and Ferguson based his tractor off the one he helped Ford develop.
They had a big legal fight because Ford didn't like him building his own tractors.
Any pics?
rusty ol ranger
2.9 Mafia-Don
7,486
Michigan
177 CID
Thats a TO20 or 30. It was built after henry ford pissed off harry fergusion and basically told henry to go F himself.
Very very similar to a N ford except its OHV.
Continential built engine IIRC. Thats a good deal at 550 bucks even if it takes a bit to get it poppin
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
Any pics?
If my link works in my post, there’s pics, I don’t have any of my own yet.
Interesting, guess that would explain things. It seems to have a lot of the “better” sorts of things that I can see from later production N series, just the early grill. I’m guessing it’s 12 volt since it has an alternator
Dug out the big trailer this morning and found my f-150 needs a spring hanger fixed…
rusty ol ranger
2.9 Mafia-Don
7,486
Michigan
177 CID
Throw a triangle on it and drive it home.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
That's kind of what I'm afraid of with my 08 Explorer...I'm sure the engine would be fine, but the independent suspension leaves a lot to be desired in longevity while towing. If I load the 2100lb trailer up with my tractor and all its implements/attachments I'm right below the max tow capacity of the Explorer...not sure how often I'd ever need to haul every single implement/attachment, but with just the trailer and tractor with loader, mower and box blade, or loader and tiller I'm at almost 6k.
I was thinking of an F150, but they honestly don't tow much more than my Explorer I don't think, at least not in a 4WD configuration. I don't need a crew cab, an extended cab long bed would work just fine for my needs, I have the Explorer if I need to haul people, when I need to tow I'm not hauling people LOL. Looking around at late 90's up to around the 2008 F150's they don't have much more than an 8k towing capacity it seems at least from looking around on the ole Googlator.
The Explorer seems to handle the trailer just fine, no issues maintaining control at all, and doesn't squat the back end of it down like I thought it would...if I tried this behind my Jeep Grand Cherokee I'd probably be hitting the bump stops LOL. I have the brake controller for the trailer and the trailer has brakes on both axles, one of the reasons I bought it was both axles have brakes, a lot of them I run across only have 1 braked axle....I'd rather have as much braking power as I can, I'm not trying to be in a race, its the stopping I'm far more concerned with....which brings up another point, I wonder if an F150 has more or less the same stopping power? Solid rear axle with an F-Series pickup would be better for sure, if I could find one that someone bought to actually use as a truck that had the max tow package would be great. Maybe an F250? I guess that would be more than plenty of truck, but at some point I'd like to get a dump trailer too so should I just wait and pickup and F250? I've seen a few tow dump trailers with an F150 but you can't put much in the trailer because they're pushing 5k empty, and an 8k towing capacity of an F150 don't leave much material capacity.
I honestly don't think I'd want to be doing this very often at all with the Explorer....I've already dealt with the wheel bearing issues last year they aren't cheap, and as large as they are, you'd think they'd hold up much better but they don't. The engine is fine, I question the transmission's capacity though pulling like that. From what I can tell is the 6 speed automatics aren't that great either.
85_Ranger4x4
17,817
SW Iowa
I don't live out west like you but around here I have done fine for years hauling my biggest tractor with a F-150.
It might weigh 6k + trailer, between tractor pulls, plowing bee's tractor rides/shows... nary an issue.
Dump trailers are heavy, never pulled one.
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
A tractor that small you “might” be able to pull on a trailer with a ranger , I brought my 63 ford 2000 home on a small tandem axle trailer with a V6 escape 50+ miles from home with no issues. I did try using my ranger once to tow it to a small show, was way too much for mine, wouldnt want to do it again.
