Trac-loc gear oil
kimcrwbr1
46
maplevalley WA
2.8l
I put a limited slip differential in my truck and was looking for the best oil to add to the axle. Will 90-w with a friction modifier be good enough. I bought a used l/s carrier and 3.73 ring and pinion and have it dialed in pretty good preload, run out and gear pattern but didnt put new clutches in until I see how well it performs. Any input appreciated.
kimcrwbr1
46
maplevalley WA
2.8l
I have a gallon of volvo penta 75w90 synthetic I was thinking of putting in the axle. Is the additive necessary if you use a high performance sync?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
It should say on it if you need to add friction modifier or not.
75/80w90 will be fine.
kimcrwbr1
46
maplevalley WA
2.8l
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
Either run 80w-90 with 4oz of Motorcraft friction mod (like 5 bucks at the dealer) or run 75w-140 synthetic with no friction mod.
Putting a used Trac-Lok in is about as useful as tits on a boar.
Either put new clutches in or a locker. There is a article in the tech library about using extra clutches to stiffen up the Trac Lok.
-PlumCrazy
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I noticed the Valvoline 80W-90 says "for limited slip" right on the bottle. I assume that means no friction modifier is necessary for it either.
Sent from a Commodore 64 using a 300 baud modem
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
I run it to be safe. I even run it with my locker.
-PlumCrazy
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I'm not claiming to know anything.... but it seems to me that somewhere I've heard or read that too much is a bad thing. Is that true?
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
It grips harder if you run too much. It will grip then slip then grab again.
-PlumCrazy
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
It will grip less if you run too much....
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Got this from Valvoline's website:
Valvoline High Performance Gear Oils meet or exceed API Services GL-5 and GL-4*. The inclusion of Limited Slip Friction Modifier in this product makes it unnecessary to add additional friction modifier (Ford M2C118A, Chrysler MS-5630, or GM1052358) in most vehicles.
http://www.valvoline.com/pdf/high_performance_gear.pdf
On a side note, down at the bottom it mentions a Valvoline Syncromesh for manual transmissions was released in September..... might need to give that a whirl.
kimcrwbr1
46
maplevalley WA
2.8l
Well I should have gone with my first instinct. The clutches are shot time to break it back down. I can spin one wheel by hand with the other on the ground in neutral with little resistance. I kind of expected it just got in a hurry before the rain sets in. Will it hurt to run it like it is until I get new spiders and clutches together its basically just a open carrier as it is. Oh well live and learn the school of hard knocks
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
You are correct.....I am an idiot.lol I described exactly what a Trac lok does with straight gear oil.
-PlumCrazy
kimcrwbr1
46
maplevalley WA
2.8l
I just got the clutch set for my 7.5 trac-loc. I got 6 steels and 8 frictions is there any particular order that works the best. I will pull the carrier out tomorrow and remove the ring gear to get the spring out any advice on setting up the clutch packs would be appreciated.
