Towing
miller time
rockfalls IL
FORD
3.0 duals out the back 4.0
Can anyone tell me the tow spec on a 3.0 2000 ex cab 373 gear truck and a 4.0 1999 ex cab 4.10 gear
Please and thank you
gw33gp
Ham Radio Operator
536
Costa Mesa, CA
4.0 SOHC
33"
You need to indicate which transmission you have also.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
miller time
rockfalls IL
FORD
Both are automatics
8,369
2WD and 4WD matters as well
Page 9 here for 2000: https://www.fleet.ford.com/truckbbas/non-html/2000/bbcamper.pdf
Above would apply for the 1999 as well
GCRW-Gross Combination Weight Rating is a weight to watch out for, say truck weights 3,500lbs and driver/passenger weigh 300lbs, then say you put 500lbs of gear in the bed:
3,500+300+500= 4,300lbs
Say your truck's GCRW is 6,000lbs, then minus 4,300lbs = 1,700lbs
So max trailer weight on this trip would be 1,700lbs, NOT max trailer weight listed above
If GCRW was 7,500lbs then minus 4,300lbs = 3,200lbs, NOT max trailer weight listed above.
And just as a heads up, if you think trailer weight will be over 50% of vehicle weight then use trailer brakes, it is required in some places, but generally a good idea in all places :)
turbo91xlt
63
Goshen, NY
1992
If you're looking to tow then the '99 4.0l with 4.10s would be the better of the two.
