Bronco648
- May 23, 2019
- Reaction score
- 102
- Location
- Chicago-land, Illinois
- Make / Model
- XL
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3
- Automatic
- 2WD / 4WD
- 2WD
- Tire Size
- 15"
To the OP: I just towed a trailer similar to the one you posted a picture of (on eBay) from Chicago to Louisville and back over the long weekend. My truck: 2004 SuperCab with 4.0, auto & 4.10s. Our trailer (1962 Broken Arrow TePee) weighs ~2500 lbs. I use a load distributing hitch (mostly because I have one not because I can't figure out how to get the tongue weight correct). The Ranger pulled it just fine but had a sweet spot right at about 70 mph (as indicated on the speedo - ~67 mph as indicated by the Scan Gauge), which was ~2400 rpm in O/D. Yes, I towed in O/D without issue, the tranny never hunted for the correct gear - that said, I-65 thru Indiana is pretty flat (YMMV). My Ranger also has a cap on the bed. However, wind resistance was/is an issue and I'm thinking about a 'wing' to help force the air over the trailer. Additionally, I'm seriously considering adding brakes to the trailer and a trailer brake controller to the truck. If you're aware of road/traffic conditions, you should be OK (WRT braking distance) but trailer brakes add some peace of mind. I saw anywhere from 12.3 to 14.3 mpg towing and 20+ mpg driving around without the trailer. HTH.
Here it is with my wife's old Escape (which also towed it just fine).
