lil_Blue_Ford
- Aug 6, 2007
- 6,129
- Butler, PA, USSA
- Ford
- Engine Size
- 4.9L
Are you sure that wasn’t me you saw?That never once crossed my mind! Even tho I saw a man in middle of a busy intersection working under his vehicle. Stopped ask asked if I could be any help, and he explained he was setting it uo to drive home with his front drive axle.
At least once, maybe twice I have been stranded some way and it did not occur to me to do that! That's ADHD in bold, capital letters!
Not too long ago I snapped the U-joint cross in my F-150. Right in a busy intersection, nearing rush hour, in the city. I had debating bringing an impact but was trying to keep what I took to a minimum. My 12 point wrench became a horseshoe when I tried to get the driveshaft bolts out. Since the joint that didn’t shatter was one I had replaced, I popped the u-joint clips out and knocked the joint out. Right in the middle of the street with a loaded trailer. Cussing like a sailor the whole time. Locked the hubs in and limped 30 miles home on the front.
The problem with driving on the front axle is that the rear driveshaft must be completely removed. If it’s still connected to either the axle or the T-case, it will still spin. If you’re loading the front on a tow dolly, then load it up, pop the driveshaft off the rear axle and tie it up out of the way. That way the rear axle spins, but since the driveshaft isn’t connected, nothing else spins. If you would say, load it on a car dolly and disconnect the driveshaft from the transfer case and tie it up, the rear axle is going to try to spin the driveshaft and damage things. I made that mistake once and let me tell you, that can cause a LOT of damage in a hurry. Thankfully it was a truck that was going to become a trailer project so it wasn’t the end of the world, but it even put dents in the frame rails on a box truck. So you just have to be aware of what is going to spin and what isn’t.
