ForgedCrank
- May 30, 2024
- 129
- Indianapolis, IN
- Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3
- 2WD / 4WD
- 2WD
I have a very stuck timing belt crankshaft sprocket on this '94 2.3L. I've tried the steering wheel puller trick with 2 different ones, and they just keep bending. I even used hose clamps to bind the things to keep them from spreading, but they are still bending at the end and it's going to end up cracking the aluminum housing, so I can't push my luck any further with that method.
Does anyone have any other ideas on how to get this thing off? The rotunda tool is around 400 bucks in ebay money, and I can't find any aftermarket equivalent.
Are there any other voodoo spells you guys have used to get this thing off? the crank main seal is leaking and I've got this all torn apart and now I'm stuck.
If anyone is in the Indianapolis area and has the tool, I'm willing to leave a healthy deposit (enough to buy a replacement) and even some rent if I can borrow it for the day.
I don't know what else to do.
