Tire size and gearing
LasPulgas
Elk Grove, California
I'm looking at a 1999 F250 4WD with a 7.3L diesel. The factory tire spec calls for 31.7" diameter tires. Would 35" tires warrant a differential gear change? Thanks!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Not with the 7.3. It's got enough torque you wont even notice the difference.
8,370
Go here: https://therangerstation.com/tech_library/Gear_Tire_RatioChange.shtml
Fill in the blanks
But as dirtman said diesel engines torque is much higher than gasoline engine, but its really up to you
speedo will be off
Drivers door label has Original tire size and the axle code number for current ratio, seen here: https://www.blueovaltrucks.com/tech-articles/axles/identify-your-ford-truck-axle-from-the-door-sticker/
Use Original size tires, if different than current, for the calculation
If you have 3.73 ratio and calculation shows "New Ratio", with larger tires, as say 4.14 then a 4.10 ratio(closest to 4.14) would make ratio 3.73 again using the larger tires, so speedo would be correct, lol, and driving and towing would be same as before the tire change
Problem with 4x4s is that you have to change BOTH front and rear ring and pinions when changing axle ratios
