Tire Question
Alan_nc
140
US
Ranger Splash
94,3.0, 2wd, splash, auto
Currently has P225/70R14 tires
The truck is not driven real regular and I'm try to get away for the least I can for new tires.
P195/70R14 tires are over $100 less. I check the actual measurement differences. I know the speedo will be slightly off and they will wear out quicker, but are there any real problems?
Is anyone doing this or has done it?
RobbieD
2.9l Mafia
3,449
Georgia
For what it's worth, the P195/70R14 is listed in the sales brochure and spec book for the 1994 Ranger (it's the smallest size listed). Can't recall if I've ran that size before (probably), but I'm guessing that you'd be OK if you keep it below 120MPH. : )
sgtsandman
Aircraft Fuel Tank Diver
12,637
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The tires in question are smaller, so the truck will move slower by about 4 mph than indicated. Assuming that the original size was reading accurately. Rangers tend to indicate about 2 mph fast in my experience. So, you might actually be going 6 mph slower than what the speedometer is telling you. I used this site to figure out the tire size and rough effect to indicated speed.
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I did that size swap with my 92 2.3 ranger. reg cab/2wd/3.73’s , didn’t notice much difference, was a cheaper tire to buy.
Blue 92
56
Pacific Northwest
Ranger Supercab
I've got 215/70 R14s and need new tires too. What brand of 195s are you looking at?
Alan_nc
140
US
Ranger Splash
I'm not really a fan but Firestone seems to have the best price here. Just under $300 for the 195's, installed, out the door
Zmans
57
Delaware
Ranger XLT
What sgt says is true, use the calc. FYI your profile is staying the same your just playing with width atm.
1990RangerinSK
1,312
Saskatchewan, Canada
Wrong.
225-70R14 is 225mm wide. Profile is 70% of width. Radial Tire, fits 14 inch rim.
195-70R14 is 195mm wide. Profile is 70% of width. Radial Tire, fits 14 inch rim.
So, your 225/70 tire has a profile of 157mm. It is a total of 26.36 inches tall.
Your 195/70 tire has a profile of 136.5mm. It is a total of 24.748 inches tall. That's a height difference of 1.61 inches.
55trucker
183
Oshawa, Ontario
mild
Curious:
how'd you end up with a set of 14" wheels/tires on a Splash?
the wheels should be 15x7", the tire 235/60/15
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I got Falken wildpeak LT's for both my ranger and F150. I am very happy with them.
Zmans
57
Delaware
Ranger XLT
Wrong.
You’re right I’m smoking something again, there’s a 6.9% increase in circumference. So at 60 mph your at 4.1 mph over your speed using a 225 vs a 195 with the same sidewall listed 70 profile. Kinda the same reason we always ran taller tires with the old 3 spd trucks that ran the 3.07 rears just to gain mph for the highway. No need for me to ramble on. What’s the factory tire size for the truck? I’d say stick to it if you don’t want speedo inaccuracy. And everything else you said sk.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I would go to a website like Tire Rack, for example, and look up 225/70's in a tire you like, then look at the chart showing available sizes and compare diameter. A 75 series tire is usually cheaper than a 70 series along with being taller so maybe a 205/75 would save you a little money and not throw the speedometer off so much. A shorter tire will make the speed show higher than it really is, a taller tire will make it read slow and could get you a ticket.
