Tire Pressure
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Grump it wasn't that way!!! I love arguing... I apologize for making it sound like I was being an abusive student sometimes. <------ read between the lines. You say whatever you want man, and know even the most honest of my arguments will never be intended to be angry or hurtful. You're good people. I just love to argue... so it's my fault.
07nhbpsi
17
Monroe mi
Correct--I ran 10 ply's (load E), on the FX4 04 level two, so I may have spoiled my ability to rate "ride comfort"-The 04 was a "hard as a board", but when I parted with it at over 180,000 miles, it was still a sad day. Ride comfort on this new one, is soft/very comfortable, with great suspension response/shock control. Not much rain in our area, (haven't driven out more than 150 miles), but there are quite a few reviews on Tire Rack, with some mileages in excess of 70 thousand.
Yes, I have a set of BFGs on my 2010 and have 70k on them with roughly 7-8/32 tread depth left...?? I will tell u though, they are starting to get loud and don’t hold traction as they once did....I figure this fall I will get new ones, which will be roughly another 10k on them
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
My understanding is that manufacturer set the PSI for both the type of tire and weight that the vehicle is designed to carry. Load Range E being a 10 ply tire is meant more for 3/4+ ton vehicles which usually has a 50+ PSI rating due to them being heavier out of the factory plus the ability to tow and be loaded with lots of weight in the bed. LT (Light Truck) tires are meant for 1/2 ton full size pick ups that are used as a work truck. This means being loaded and towing but within recommended manufacture specs. Because this tire is usually more flexible than the strait E rated tire it will give a better ride while not weighted down and usually installed with a PSI of around 35.
It blows my mind someone would install an E rated tire on a Ranger where many are rated at under a 1/2 ton carrying capacity so the side walls will not see the weight nor does it need the standard 50 PSI in the tires. Talk about kidney busters right there. Unless you go off road with your Ranger an LT rated tire is to much for the average person to need. If you tow say a camper or an enclosed tool trailer then I can see the LT's being on a Ranger but for the average use most people give a truck, a trip now and then with a load, LT's and E rated are way above what is needed and recommended for tires. I'm willing the new rangers with LT tires have the tow package installed because the weight of the new Rangers do not meet the specs of the LT tires.
Yes I have worked in a few Tire shops over the years, trained in tires at the age of 14, and have had some good arguments with management over what even the "LT" stands for. It took a good year for me to convince the manager of one that LT didn't just mean Light Flotation but included others to.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Yes, you have your answer--My FX4 was "off road" all the time! :icon_thumby: That's were you have the most full, here in Arizona. The sidewalls heavy construction saved us more than once, from the jagged rocks, and thorns the size of 8 penny nails!!
The exact GVWR was
Curb3,606 lbs.
Gross Vehicle weight rating5,440 lbs.
the rear leaf spring stacks, were awesome!
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
2.3 Turbo, 350, 5.0 HO
Stock, about a foot, about a foot
LT 265/65 R17, P285/70R15 & P195/65R15, 820-15 & 500-15
BFG's-Original size, 8 ply rating....
Our 2019 Ranger was special ordered from the factory (by the dealer) with LT 265-65-R17 tires. Placard on the door specifies 38 PSI.
Sorry if I missed this but where did you come up with the 44 psi? Ours actually did have 44 psi when we bought it and the ride was harsh, dropped the pressure down to 38 on the drive home from the dealership and it was so much nicer.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Are your tires 6 Ply?? Load range C? Are the tires filled with straight Nitrogen? Also, this is a "cold" setting--My tires are inflated with Nitrogen, load D and do not vary the air pressure, cold, or hot. We are only 6LBs different, and the ride comfort, a perception, probably diff between a 4x2/4x4.
If you adjusted this pressure after the drive, take a look at the pressures, in the morning/cold. Might be diff/less???
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
Just compressed air. As the sticker I posted shows they are load C tires and are LT.
What does the door sticker on your truck show as the specified pressure? The Engineers at Ford determine optimal pressure is based on the tire size, type and load rating of the vehicle.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Wasn't sure if that "C" on the end, was your load rating--Mine does not have any letter/rating-indeed, the tires that came on the truck are 2 ply!!! Took them off before the odometer hit 300 miles! The "guideline" sticker for the tires I took off, is 35PSI. I 'm sure this probably was relevant, for the original's.
I haven't been able to even give them away, still sitting in the extra bedroom. Bridgestones.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
You keep old tires in your bedroom?
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Ya, Doesn't everybody!!!!:p I'm a car guy, the wife is very understanding!!!! If I put them in the Garage, the 130 plus, degree heat in the summer, will destroy them!!! The solar heat inside the garage, is extraordinary!!!!
I parked the Cadi inside on July 4th, years ago, came back in Oct, and the tires where ruined/flat spotted from sitting too long. Had to by new ones!
Very cautious about what I leave in the garage, during the summer!!:cool: No aerosol cans, ect!!
