2.3L ('83-'97) timing job
jack frost
TEXAS
FORD RANGER
4 cylinder
the timing belt and tensioners was replaced on my 96 xlt 2.3 ext cab once at around 150.000 its now around 280.000 truck runs great except for the electrical short in the speedometer's circuit board which im looking for a new instrument cluster with a tach. so anything i should check and or change while im there.
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
At that many miles it wouldn't be a bad idea to do the water pump and thermostat, and definitely get the timing belt kit with the tensioner, they're like $3 more and the tensioner separate is like $15...
jack frost
TEXAS
FORD RANGER
4 cylinder
sorry for the late reply been out of pocket for a spell...i just did a water pump thermostat , and water neck . when i got it i did eng oil ,man trans oil and dif oil all looked good ... then plugs n wires fuel pump and filter cool temp sensor and temp sensor a new front header panel and all new lights .then #25 fuse fuse kept blowing traced it to the back of speedometer just got the worm gear in and cleaned all the old one out of the other gears hope this fixes that issue we will see tomorrow.
jack frost
TEXAS
FORD RANGER
4 cylinder
I DID IT ALL ....now trying to fix speedometer from blowing # 25 fuse
