MrEvilPirate
- Apr 2, 2017
- Reaction score
- 0
- Location
- Central CT
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
- My credo
- MAGA!!!
So I got the sheared off water pump housing bolt out. Removed the idler pulley and hit it with PB blaster and a hammer every night for a few days. Said a prayer to the car gods and clamped on the vice grips, got it out.
Put everything back together, new tensioners in, fired it up. No more rattle. Rev'd to 2500-3000 no more noise. Very happy.
One issue... The rear passenger side tensioner is leaking oil. I tightened it up, removed and replaced, nothing is stopping the leak. It was not cross threaded at all. Torqued up to 65 lbs, still leaks. There was only a washer at the tensioner by the water pump housing. You tube videos indicate that there is no washer at the rear passenger tensioner. I ordered one from Ford and am going to install it to try to stop the leak. Any opinions on this option? Anyone else had a leaky tensioner here before?
Side Note - Part numbers on the tensioners I removed matched the new ones. Someone had done this procedure before... Hopeful to take this truck to 200k... at 152 now.
