Timing chain deflection...
airborn_ranger
Law Enforcement
Florida Panhandle since 12/2010. Now Phoenix AZ.
Stock
Stock
31x10.5x15
Your character is demonstrated by your actions if you knew no one would ever discover them.
Bros, Engine is 200x (single-digit 2000, i.e., 2001, 2002, etc.). 130,xxx miles. What is maximum allowable deflection of the timing chain, and does it have a tensioner? The truck in question has approximately 3/4" deflection. The teeth on both sprockets appear to be symmetrically triangular, with the valley between the teeth a perfect "U". There is no tensioner mounted. Is the chain worn too much and in need of replacement? TIA.
crazypj
Altamonte Springs Fl./Bridgend South Wales
Mazda
2.3L
Ford say change the chain at 120,000, I'm interested to find out when the chain HAS to be replaced as I know the factory service is conservative
Guess I'll have an oil analysis done next oil change and see if there is excess 'iron' in the oil
