throttle cable on a 2.5 liter engine.
need info
15
Its a bit of a learning curve, but old dogs CAN learn new tricks.
What you termed a carb is a "throttle body". It measures the throttle plate opening and gives the reading to the computer. The computer uses that and other sensors to calculate the amount of fuel to inject.
FYI; what looks like a idle control screw is NOT! It's called an anti diesel screw and doesn't control idle. The IAC (Idle Air Control) valve on the side of the intake on the engine side of the throttle body controls idle.
thanks for the info, ever since I took up the slack in the throttle cable it runs like new. I wonder if the signal to the computer was being fouled up when it had much slack. The engine since I purchased the truck a few years back has always had a rattle noise during acceleration, a preignition type of running. Perhaps the term dieseling is correct, I am not sure. Well now on acceleration it has a lot of pick up and it does not rattle much at all. It has better pick up and go. Thanks to the broken bracket and the help from you guys, I have a really good running truck now.
Kirby N.
March Truck of The Month
