This 2019 Ford Ranger FX4 has an open front differential
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
exactly what is the front axle? specs say DANA Adventek 190mm 3.73:1
is there a BOM on the axle?
spline counts would be handy to know.
along with the spline count it would be interesting to compare the internals to Jeep Advanteks.
perhaps FCA has an agreement with DANA about parts commonality for the Advantek??
sgtsandman
Aircraft Fuel Tank Diver
12,636
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
My FX4 Super Duty was limited slip front and rear. I can see a base model 4x4 being open in the front, but I expect more from a FX4.
I would like to see at least a limited slip in the front. I plan on putting a Torsen in the front of my 2011. The Dana 35 SLA isn't known to take a locker well. Can you do it? Yep. Will the axle live long after it's been engaged a few times? Maybe, maybe not. I'll/we'll have to wait until we have some sort of info in the 2019 to see what is available and what kind of load and abuse it can take.
v-8power
31
Huntington, In.
I can try to get the spline count tomorrow. We don't assemble the diffs but we do the the ring and pinions at work. People wanting to do a gear change is in for a rude awakening since its welded and not bolted.
v-8power
31
Huntington, In.
I can try to get the spline count tomorrow. We don't assemble the diffs but we do the the ring and pinions at work. People wanting to do a gear change is in for a rude awakening since its welded and not bolted. We used to do the jk model ELD but not the new jl ELD. We build the super duty ELD pigs at work.
Bird76Mojo
1,265
IL
The ring gear is welded to the carrier? So it will require an entire new carrier for every gear change?
sgtsandman
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Welded? That stinks. So much for any upgrades then...
17,810
SW Iowa
There has to be some anti DIY'er engineer still laughing that the ring is welded onto the carrier...
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
I saw that on a Jeep forum.
time to research and see what they do for gear changes.
v-8power
31
Huntington, In.
i didn't get a chance to get any pics today but the laser welder only runs 3days a week. Another thing i think is messed up is what we/I call a carrier, at work it's called the case.
Revtach
6
New York
If I can get my hands on a Torsen for my front SLA 35 I would put it in. Of course, a selectable locker for the front would be "better", but I already have a Torsen in the rear and I would want it to match. For the type of offroading I plan on doing I would not need a front locker anyway. I've heard that Torsens front and rear allow a truck to kind of slip it's way through trails. It may not be as confidently done as lockers front and rear but if it gets you through the trail then it's good enough.
A Torsen in the front is probably a better option for most people when it comes to IFS trucks. I've never seen an IFS system that could withstand a locker + abuse. Seems like most people don't understand that so they are better off with a Torsen since it's easier on the axle components. I'm pretty sure the 2016+ F150 Raptors all come with a locker in the rear and a Torsen up front. The Colorado ZR2's are locked front/rear with IFS...I wonder how often dealers are getting customers asking them to repair their ZR2 front suspension after going offroading.
sgtsandman
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
If you got the money, here you go: https://torsen.com/product/ford-ranger-dana-35/
v-8power
31
Huntington, In.
Here is what the weld looks like. Sorry it took so long but like I said they don't run it every day.
27306
Revtach
6
New York
Any idea why they switched to welds in place of bolts?
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
welds can save weight. a robot can do it. bolts have heads that stick up, so welds eliminate that. welds are easier to balance if needed. less machining, no holes and threads. its faster.
just a few. but i could be wrong on all lol
