thermostat housing bolt
jerkyboyxiii
89
nebraska
ford ranger
my 01 was leaking coolant. One of the bolts snapped. Anybody know, offhand, what the length and pitch is for the three bolts that hold the housing onto the intake manifold? None of the stores have replacement bolts; I have to go match mine to their bulk bolts.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
For the V6~4.0L~SOHC, believe these are the 3 Bolts connecting TStatHousing to the EngineBlock:
~ M6*1.0*75 = Metric6mmDiam * 1.0mmThread * 75mmLong
~ 3each FordMotorCraft# AllThread M6*1.0 cut in ~85mm lengths, each with a couple of JamNuts & a Washer, works if you can't get proper bolts.
SAE 1/4*20 Bolts\AllThread (common in hardware stores) is slightly larger but close to M6*1.0; may need to tap out hole.
AntiSieze\Vaseline on the bolt tips for the next poor bas'ard working on the TStatHousing.
Click here for info on swapping from JunkPlasic TStatHousing to an improved Aluminum version.
Josh B
1,986
Oklahoma
If your wrecking yard is convenient that might be a good place to start
jerkyboyxiii
89
nebraska
ford ranger
Thank you, kindly, Dillard!
jerkyboyxiii
89
nebraska
ford ranger
Why didnt ford do something smart, like that???
Milkman5687
30
North florida
Ford ranger
When mine gave up the ghost I had the shit luck of the front bolt breaking off about an inch above the block. It was totally seized (tried penetrants, new vice grips, etc.) What worked was welding a nut on top of the broken stud and backing it out slowly. I was so happy to see that bolt start moving
jerkyboyxiii
89
nebraska
ford ranger
We have been hitting the bolt w a torch n pb blaster for a few days. We will weld a nut on this weekend. Im really hoping it starts moving w a nut too, millkman.
Milkman5687
30
North florida
Ford ranger
Make the first weld count since you really have limited attempts before it's gone. Weld the biggest nut that will sit on the bolt so you have more room for weld. It will come out, it is coming out.
jerkyboyxiii
89
nebraska
ford ranger
Thanx, yall. Ill post up w success or failure…
