The "Y" (wye) in lower rad hose... can it be bypassed?...
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
... e.g. if the infamous Coolant Temp Sender ELBOW (ell) does its inevitable crack-leak thaaang? The LOWER rad hose is mainly the cooled-off coolant coming OUT of the radiator, but do I understand that this "side hose" has hot water flowing OUT of the t-stat area, providing data to the sender/gauge, before flowing DOWN to join the main "cool uptake" into the water-pump, and out to the heads-block-etc?... or do I have it backwards? :icon_twisted:
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Hello, is this thing ON?... OK, so I'm 84.2% sure it IS a hot-water recirculate path, for faster warmup when t-stat still closed... which kinda makes sense since heater hoses + heater core are actually cooling the coolant, even with t-stat closed... yes/no?
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
I'm just planning for the future, BUT... I know SOMEBODY has done this... youse guys is holdin' out on me... ;) :icon_twisted:
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
we're just testing your patience.
you do have a good question.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
LOL... like the coolant circuit over to the intake manifold (and the electric block heater), I'm thinking it's something nice to have in Minne-SO-tuh, or Banff... but down here in da sub-tropics?... not so much. It's just that replacing that innocent-looking slant-tee is a major nightmare, requiring the removal of tons of stuff, to get at the 2-ounce fitting. I figure just sweat-solder a cap on a stub of 1/2" copper pipe (OUTside dia. 5/8"), hose-clamp it in place, harmless dead-end... get a cheaper 2-end lower rad hose next time around.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Guess I'm gonna have to be the guinea pig, as it seems my "sender ell" has a small leak... which means after a long drive in this hot weather, I get the smell of fried coolant when I park and shutdown.
Will first try to sweat-solder that elbow/ell with 450degF plumbing solder... pending...
