RustyDusty
- May 13, 2021
- Reaction score
- 14
- Location
- California
- Make / Model
- Ford Ranger
- Automatic
The knock sensor is something I haven’t checked out yet, I don’t even know where it is or what it looks like. One thing that makes me question that theory is that I just checked the timing and its consistent doesnt change with the surging idle. So I doubt the surging is caused by timing being retarded by the knock sensor. Is there something I’m missing with the knock sensor theory?88+ 2.9s did NOT have a EGR.
The 89 ECM basically bypasses the EGR and the knock sensor, as the knock sensor went away with the 88+ models as well.
I would pull the EGR valve and see if its stuck open, or if the passage behind the EGR is plugged with carbon. My 87 was plugged rock solid.
Also it could be an issue with the EGR vacuum solenoid (the little can on the passenger side with little red and green vacuum hoses running to it, as well as a plug)
There is also an EGR pulse sensor, that tells the ECM what the EGR is doing. Its a little black box held on by two clips right in the vicinity of the EGR valve. There is a little hose running to the bottom side of it from the EGR valve, and an electric plug
Also, do not overlook the knock sensor. Its job is to adjust timing if it senses spark knock. However, if you have alot of valvetrain noise (ticking) it will sense this as spark knock and retard timing.
The sensor itself could also be failing.
Since the 89 ECM clears everything up i would bet on either...
1- EGR valve/system issue
2- Knock sensor issue/valvetrain noise
3- Failed ECM.
Listed in order of which is most likely to least likely.
EGR system is definitely the #1 suspect in my mind at the moment since Ihave noticed the EGR vacuum valve solenoid makes a whining/rattle noise that I can hear with the hood popped after I shut off the engine. The sound is vacuum leaking from the top cap/filter. Can anyone verify if this-means it’s defective or if it’s normal for these things? I have never removed the EGR valve but I have tested its operationby pulling vacuum on the valve and the diaphragm works and holds vacuum.It seemslike it’s time to actually take it off and make sure the hoses aren’t clogged. The EGR pulse sensor looks like it was replacedby the previous owner. A lot of parts that I’ve looked at were replaced because I’m guessing they were trying to track down this same exact issue and gave up as I have done several times now. When I take off the hose to the pulse sensor there is air being pumped out of the hose. Is there a way to test the pulse sensor?
One problem I have with the EGR system being the problem is that I felt it got shut down earlier in this thread because it was stated that the EGR system isn’t active during idle. Is that true? Or is it still being used in some capacity during idle?
