I spent the day redoing the pin assembly on the RR trailer. When I first did it, I half assed the engineering, but mostly I eye balled it, which is why I ended up dinging the fenders up. This time I three-quarter assed the engineering, but I made up a lot of templates and such to make sure the moving parts all stayed within certain radii.
From the center of the coupler, it’s 24 inches to the inside of the fenders on either side. I had that correct, but when I made the assembly, some of my brackets were hanging too low and violated that radius. So a primary design item was keeping everything that hangs down under the upper deck within a 22 inch circle for 2 inches clear all around
When I had it all put together the first time, and I set it on level ground, the front end of the trailer was about an inch and a half or 2 inches lower than the rear end of the trailer. It should have been the opposite, so when you load the trailer, it would sit level. Also, by raising up part of the trailer, it also improves clearance over the fenders.
The third item was simply that the transition from the upper deck to the lower deck was too far back, and the upper deck was too far back from the cab/toolbox of the truck. So in addition to keeping it all in the 22 inch radius, I also wanted to raise the upper deck about 3 inches, and move the pin back about a foot, which had the effect of moving the trailer about a foot forward over the truck. From the new pin location on the trailer to either corner of the upper deck is now 34 inches, and the distance from the coupler to the back of the toolbox is about 40 inches, which gives me 6 inches clear when turning. At least that’s the way I measured it.
The other thing I mentioned, is from being rusty (me and my scrap metal), and having not welded much in about 15 or 20 years, when I took it apart, I realized some of my welds were worse than I thought.
Soooo, yesterday I fabricated most of the pieces, and today I started putting it all together. I also added another feature. I put a receiver tube under the upper deck that extends through the step wall over the lower deck. It’s with the concept that if there was a trailer sitting on top of the trailer, I could drop it on a ball in that receiver, and only have to tie down the rear end. Don’t ask me why, it’s another vision and another project, but I added that receiver tube while I was doing all this work under the upper deck.
I did get it all together, but a lot of my welds were just to get it in place, and I have to go over all of them. I also need to add some stabilizing braces to the side, and to the rear, but my brain had shut down so that will happen when I go over the welds, to make sure they’re all in the proper radii.
it may look like this assembly is low, but remember that the fenders rise up about 8 inches above the coupler, so I’m hoping it will all look OK.
And, of course, I wouldn’t be happy if I didn’t have to do a little bit more wiring, so I yanked out a couple of wires out as I was working, so I’ll put them together when I get all the structure done.
Wait till the pastor sees me checking all this out in his parking lot in a week or so…
