The Ranger Clunk?
PaulZ
50
Hey Guys,
Just went through several pages of a 'Clunk' search, looked at the Tech Library but still no answer. I have a '99 stick and my pal has an '01 auto. Both make the same driveling clunk when taking off from a stop unless deliberately slow. His has done it since new, I got mine used but have checked the U-joints. Both drive great, no vibration, no noise. Several threads mentioned the 'Notorious Clunk' without saying what it is? So, what is it?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Dry slip-joint in the driveline.
PaulZ
50
Thanks man!
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Thats just the Trak lok kicking in, the clunk means its working properly.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is a TSB for Ford 2 piece driveshafts, they are well known to clunk at the slip joint. Ford sells a grease called XG-8 that fixes the issue. But there are many other things that clunk on Ford drive trains. :rolleyes:
scotts90ranger
4,356
Dayton Oregon
2.3 Turbo
'98 and newer should be single piece driveshafts on extended cab's unlike earlier versions, that was my first thought too, I think that's where any clunking in my '97 lives...
The other thought is the limited slip, if both have those (look on the tag on the drivers door under "Axle", if the code starts with a letter that's a limited slip) then that's the cause. I'd call it normal if that's the case but wouldn't be bad to check into to make sure the spider gears don't strip out if they're worn out enough.
Only other thing I can think of is transmission mount or engine mount. If either was TTB/TIB I'd say radius arm bushings because I know that noise...
cbxer55
767
Midwest City, Oklahoma
My 98 was doing that. It's a 7.5 open diff. Spider gears well rounded off on the corners. My friend who rebuilt the thing, said "they're worn but not terrible. just don't go selling them to anyone". Haha!
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Ixnay, ixnay, Public Service Announcement: FoMoCo "baby blue" XG-8 Anti-Clunk Grease: that 3 oz. tube is a whopping $28.79 at Duh Dealer, $14.30 on Amazon... and only $6.29 at O'Reilly... go figure.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
My '99 Ext Cab 4WD Manual has the so-called 1-piece driveshaft, but it still has a splined slip-joint (to compensate for suspension travel), and still relies on heavy nickel plating from the factory on those splines, which eventually wears off, and thus develops The Clunk... and benefits from being packed with the same XG-8 grease.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The only ranger driveshafts that are truly "one piece" are 2wd automatics that have the slip joint at the transmission output shaft. Any driveshaft with a bolt on yoke at the transmission or transfer case whether it's 1 piece, or 2 piece with a carrier bearing has a slip joint on the shaft and those are what causes the noise.
The ones with the slip joint at the transmission output shaft still clunk but there's not a damn thing you can do about it since you CAN NOT grease those splines. The splines are inside the transmission and the grease will contaminate the transmission fluid.
