- Sep 26, 2011
- 2
- Southern California
- Ford
Strange issue.
2003 Ranger Edge - 3.0L - 96,000 miles.
Anytime the outside temp is at or below around 75 degrees, this thing never overheats. I can climb hills, do 80 up the Grapevine, sit in traffic with the A/C blowing, zero issues.
However, if the outside temp rises, maybe about 75-80....and up, it will overheat the minute the engine is put under any heavy load (climb, traffic, etc)
So basically, this truck ONLY overheats when it's warm out.
Coolant is clean and green, no leaks anywhere. Oil is free of any coolant mix issues, plugs are spotless and engine has tons of power.
Radiator was flushed this summer and done right by a reputable rad. shop. Water pump however, has never been changed.
I'm going to guess my pump impeller is rotting away but I'm curious if there might be another reasonable suggestion for why this is happening.
