Got a new bearing, reassembled, went for a rip, everything is great!
Friends came over....went for another rip....yeah, you know the rest....
4th gear at 3500rpm is the perfect speed to jump from one mogul to the next like a dirt bike, up one side, jump 15ft and land on the down side of the second mogul. Doing that and hill climbing (the donkey is crazy at climbing, goes vertical and still doesn't go over backwards!
Now, the problem...apparently, jumping moguls is hard on the frame...the only place it was single thickness was the top of the frame in the back where I bolted the suspension on. And of course upon one landing there was a crash and the arse sagged on the drivers side. Ripped the top of the frame completely off on the drivers side and tore 3/4 way through on the right.
Well, that's not right.... ok, I have a winch on the rear so I pulled up to a couple of small trees, put the winch up high and jacked the ass off the ground dropping the suspension back into place.
and then used cargo straps to hold it all in place.
and then proceeded to hill climb some more. (but no moguls)
Since we were about 20km's from home in the woods, it was quite the drive getting home over the rocks on the powerline. By the time we got home, one cargo strap was cut and snapped but the second one still held.
Everybody says "man you beat on that poor thing like a rented mule" Well, yeah but it always gets home!
When in doubt, throttle out!!
Found another picture;
I see a cargo strap on the tire...and have no idea who did that or why. I'm guessing they were trying to pull the strap through the handle and used the tire as a pull point?? Don't know and just saw it now. The track bar (panhard rod) kept the rearend in place, it just squatted on the left.
Just leaving the shop now, welded heavy angle on top, boxing the frame completely and reinstalled my skidplate, relocated the axle position of the track bar, fixed the crushed brake line, got the broken console out right now to fix it (has been broke since I rolled it in Dec) welded the drivers seat in better and still have to install a radio noise (RF) suppressor so we can run the big LED lightbar and still have a radio. Been busy the last two days.
Once it's finished its back home again and try a little "putt putt" instead of the "zoom zoom" which tends to break parts, lol!
