Temp gauge problem for 4.0
98 ranger xlt
California
On a cold day, After about a 10-15 mile drive the temp gauge will barely get above the cold mark, the heat works fine. In the morning when i start it the temp gauge reads way below the cold mark and slowly creeps up just past the cold mark. Just trying to figure out what is wrong before i replace parts. This is on a 98 4.0 with a non tach gauge cluster. Thought about replacing the rad cap, but i don't know if that would help.
ashleyroachclip
1994 Ranger STX
1995 Explorer L
My temp gauge also reads low but the coolant is hot, heat in cab will run you out.
I have thought about changing out the sending unit , but it really does not bother me that much.
Changing the radiator cap will do nothing for the gauge.
jdanbarnes
Sioux City, IA
Well when you guys figure it out, let me know, cause I have the same issue in my 90. Temp gauge never gets over C, thinking I need a new temp sensor?
Big Jim M
30
Austin
Sure sounds like the senser has a bad connection or is kaput!
Big JIm
feellnfroggy
28
Knoxville, TN
Either CTS or you all have a 160* thermostat like I do and need swap it out for a hotter model. Thats my next move I think. I bet you all get bad mileage huh(worse than regular 4.0)
No members online now.
