Temp Gage Quit Working
ford4wd08
510
Alcoa, TN
2.8 V6
Yes, nothing wrong with that at all, racers always run 160deg thermostats :)
Thermostats set minimum operating temp, so can't help much with overheating, but 160deg should be open all the way after 8-10min so should keep the temp gauge below 1/2 full time
And 170-180deg(upper engine temp) is plenty warm for heater
Thanks for the advice as usual Ron. I still plan on changing the water pump as I'll be working on all of this at the same time anyhow.
ford4wd08
510
Alcoa, TN
2.8 V6
Changed my tune a little bit lol.
Decided that the water pump seemed to be working good. I did a GOOD flush and installed the proper 180 degree T stat in the lower housing.
Went a lot smoother than the first time I changed it, and the housing seemed to seal up good with a new gasket and rubber ring.
I decided to ditch the sender I had bought and got a new motorcraft one from rock auto. It made the gage read properly now and everything seems to be functioning as it should with bright green coolant circulating.
