Tdi conversion kit for Ranger. Want one?
fastpakr
2,832
Roanoke, VA
Potentially stupid question - can you not just reverse the polarity?
RamblerRyGuy
4
Ohio
1.9 TDI
3 inch
33’s
Graduated one of the top in my class for automotive technology at Sinclair College, Ohio.
No, you are on to something, but unfortunately with the way starter gears protrude in order to engage and catch the flywheel or flexplate and then disengage, it would not work to run backwards. The teeth are beveled a certain way to not clash teeth. I've also read that the internals aren't really designed to run backwards. With any other motor, you're totally right, though.
fastpakr
2,832
Roanoke, VA
I didn't think about the issue with the bendix not pushing out.
What's beveled about it? I can't visualize that issue.
alwaysFlOoReD
5,091
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The front of the teeth are beveled to a dull point. Makes it easier for engagement with the flexplate or flywheel. And its beveled only on one side.
fastpakr
2,832
Roanoke, VA
Interesting. I'll have to stare at one tomorrow and commit that to memory. Never noticed it only being one side before.
I'm not familiar with this starter. Would it be possible to remove the gear and flip it over?
Bird76Mojo
1,265
IL
You'd still have the spiral cut shafting that propels the gear outwards, towards the flywheel.. As far as I know anyways... You'd still have to find a reverse cut, reverse rotation to replace those parts with.
RamblerRyGuy
4
Ohio
1.9 TDI
3 inch
33’s
Each individual tooth is beveled in the direction opposite the rotation of the starter.
jmcrow1954
Ontario, Canada
Swap is easy, TDI harness is easy, getting VW CANbuss to marry to Ranger instr cluster not so much fun
RamblerRyGuy
4
Ohio
1.9 TDI
3 inch
33’s
No doubt, the older Rangers are much easier to swap engines in.
