tap noise when brake applied firmly
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
I have noticed lately a audible Tap coming from the right front brake. It doesn't do it every time, just when i have to apply it more rapidly. I have had the brake caliber off and on to check if all was intact and it was fine. I apply the brake grease where needed and reassembly. After a few times on the brake and it starts again. Any suggestions or comments are welcome. Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Well i guess im the first. If i find a solution Ill....
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Did you try new caliper hardware? New anti rattle clip?
Junk Collector
Truck of Month
4,797
Rapid City SD
So does it do it at a dead stop? Or are you hearing this under moderate-hard braking/slowing down?
I'm kind of at a loss if it's option 1... something loose in the pedal assembly/booster/master cylinder?
Option 2, I would be looking at your radius arm bushings. I have seen a bunch of them blown out inside where you can't really see... I've also seen a lot of cracked crossmembers. Maybe remove the nut/washer/bushing assembly off the back side and inspect it closely.
RobbieD
2.9l Mafia
3,449
Georgia
And another thought, for what it's worth . . .
After a recent brake job, I had a noticeable, even loud, "clunk" noise from my fronts when I braked. I had had the rotors turned, and noticed that the finish looked grooved, not perfectly flat. Going over the rotors with a die grinder and sanding disc took most of the grooves out, and almost made the noise go away. A new set of rotors completely fixed the problem.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Well I guess It spit out the anti rattle clip, Ill pick one up and see if that's it. Dorman product maybe.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
If you push the gas and brake all the way to the floor simultaneously while driving, your truck will take a screenshot.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Try that and get back with me PJ, sounds like something for a trumpy bear.
GODS WILL the crusaders say. Nice Try
