Tailgate width
rumblecloud
579
48022
Ranger Splash
1-1/2 inch front leveling
Stock
P235/75R15
What's the worst that could happen?
Trying to help a friend with a tailgate question. Checked specs and searched, but no actual measurement.
is there a way to tell the difference between a Styleside tailgate and a Stepside tailgate aside from the measurement of the width?
Thanks
r
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
Roert42
2,328
Kintersville, PA
Ranger XLT
4.0 SOHC
They look identical beside the the with too me.
ericbphoto
Overlander in development
Forum Moderator
9,043
Wellford, SC
6"
I can measure a stepside tailgate if you need that.
superj
685
corpus christi, texas
ranger edge
V6 of power
none
none
235s
Grew up in the 70s, 80s, and 90s
superj
685
ranger edge
V6 of power
none
none
235s
04 flareside
69588
5,156
Handle is in the center of course
The Badge looks to be the same distance from the edge on both
So if you were to "eyeball" the handle to badge distance it should be easy to tell the narrower flareside tailgate
Diagonal line from center of handle thru center of badge is well above lower body line on regular tailgate and lower, almost at the lower body line on flareside, if you have a picture of the tailgate
superj
685
ranger edge
V6 of power
none
none
235s
Does the regular tailgate have 8 bolts?
69589
5,156
Yes, styleside(regular) has 8 bolts for access panel
rumblecloud
579
48022
Ranger Splash
Stock
P235/75R15
Hey guys thanks. Confirmed my friend's tailgate is from a styleside based on visual cues of the emblem to handle distance, measurements and the eight holes for the access panel.
5,156
Yes, for sure regular/style side based on distance
superj
685
ranger edge
V6 of power
none
none
235s
Yup, it's got 14 slots beneath the 8 bolt area. My flairside has 12 slots
