- Aug 31, 2021
- 107
- Roanoke VA
- Maxda B3000
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 235/75-15
I read in the manual you can take off the tail gate, and I am GUESSING that is so it doesn't flop and bang around if you have stuff in there that is too long and you want to lay it flat (?). I haven't tried taking it off, but I see how the cable supports come off. I'm going to need to get some long stuff that I want to lay flat in there so I need to get savvy on that.
Also, I just noticed there is a lock under the tailgate. WTF is that? I don't remember seeing anything in manual about it yet. I can't tell if it takes my regular ignition key because the little protector plate is stuck, will have to be soaked a bit. That's weird. You can get to it with a key but its placement isn't obvious. What does it lock?
