A4LD_Nghtme
- Nov 7, 2021
- 55
- Twin Bridges, CA
- Bronco II XLT 4
Hello,
So I have 3 guages that don't work like they used to.
The first is the tachometer. Sometimes it reads really high and then drops to 0. Then sometimes it comes back from 0 to normal and sometimes does repeated drops to zero and then back up then back and forth between a reading and zero.
The second is the Oil Pressure Guage. It used to read somewhere in the middle then one day it dropped just above "N" and seems to sometimes drop below that closer to "L" and then goes back up. I have grounded the sensor wire and it raises the arm to around "M" but does not max out at "H" like I read it should.
And lastly the temperature guage seems to sit really low around "N" and "O". It used to sit just below the middle. I do have a lower temp unit installed that I believe is a 180 degree vs the stock. I have overheated up steep incline stretches of highway and it gets near the "H" but I always stop before it goes too far. Then it cools back down to where I mentioned earlier. I had a cracked vacuum fitting that leads from the TB down to the charcoal box that I fixed cause I thought that may be leaning it out and overheating it but not sure. Never overheats downhill or on flat.
Any ideas on these issues or how to fix them? This thing is so close to being ready for interior and exterior refurbished but I need it running 100% before I can fathom spending the dough and paint and reupholstered interior
