TCC solenoid wire runs to pin 53 on computer, but MANUAL TRANS computer won't have the firmware/software inside so pin 53 won't do anything
You need an automatic trans computer
People have used Speed sensors to manually ground TCC solenoid
Yes, 12v for solenoid comes from EEC Relay Power On wire, they are red and run to fuel injectors, IAC Valve, EGR solenoid(if so equipped) and computer pins 37 and 57
You can tap any one of those Red wires to get the Key ON 12volts
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
