Sway bar questions
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
Did the 2004 4x4s have thicker sway bars than the 2002 2wd?
Will a '95 Bronco 4x4 rear sway bar fit on a '02 2wd?
I'm trying to get my 2wd ready for autocross.
85_Ranger4x4
17,817
SW Iowa
Bronco rear sway bar will not fit. The frame is narrower on a Ranger and your stock axle is smaller diameter so the Bronco clamps won't fit.
Ranger/Bronco II rear sway bar 83-11 will fit. 2wd BII has the heaviest followed by older Rangers.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I took a rear sway bar off a f150 and bent the arms in on a 20ton press. It's on my race truck now.
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
summit used to carry a thick rear sway bar that would fit a ranger, not sure if they still do and don’t remember the thickness but it was thicker than the factory bar on my 93. too cold to measure it now but I still have it, its on my ranger trailer.
cbxer55
767
Midwest City, Oklahoma
Hellwig used to make them. Don't know if they still do. I have them on my Ranger, front and rear. I don't know if Hotchkiss made them for Ranger's or not. I know both still make them for my 04 Lightning.
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
Summit has the Belltech and Hellwig sways, but if I could get away with thicker OEM bars, I'd like to go that route to save money.
I tried looking at that link, but I couldn't follow cause I'm a total Ford noob. I don't know what goes with what.
I found an OEM 2004 4x4 front sway bar online and wanted to confirm whether that was thicker than the 2wd front sway bar. I also found the 4x4 rear sway bar and wondered if that were any good or if I should hold out for something thicker. Currently, I have no rear sway bar. Figured I'd add one while the bed was off.
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
since you mentioned 2WD,
98+ 2wd front bars are different between coil spring and torsion bar systems.
the coil 2wd bar is wider to clear the spring bulges in the frame.
if you want a real thick front bar try Explorer or Sport Track.
EDIT: for torsion bars, not coils
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
Interesting. Never took that into consideration. I’ve got the coil springs up front.
85_Ranger4x4
17,817
SW Iowa
Rear swaybar looks like this:
Yellow is the bar, red is the mounting hardware.
83-92 is 3/4"
93-11 is 5/8"
Bronco II (2wd) is 1"
Explorer is bigger but mounts differently and you don't have the brackets welded on your axle for it.
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
83-92 is 3/4"
93-11 is 5/8"
Got it. Thanks.
Belltech rear sway is 3/4"
Hellwig rear sway is 7/8"
I contacted a junk yard that supposed to have Bronco II stuff. I'll see if they return my email.
85_Ranger4x4
17,817
SW Iowa
I wouldn't hold your breath, 2wd BII's are SCARCE.
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
mine is a hellwig- 7/8”.
