So I swapped the old FPR back and it still won't start. Plugs are getting spark, they smell like fuel and the schrader valve has fuel to it, checked all the wiring and didn't find anything obvious out of place. Backstory is this. I bought it about a month ago for $300 ran and drove although not very good. I did the basic tune-up stuff and it got:
1. new wires and plugs old ones were melted and plugs wore out and fouled badly.
2. new cap and rotor
3. new air filter, PCV vavlve, oil and filter change and it ran a little better
Put the old tachometer (run off green wire in the engine bay) and timing light on it and tried to adjust the timing and engine idle according to what the manual said. Helped a little but not much it still had a rough idle, surging and wouldn't drive very well ie.. hesitation, stumbling,
4. new TPS, IAC valve, MAP and TPS
Those helped some but again didn't really solve the previous symptoms.
Tested the fuel pressure at the schrader vavle and it was low.
5. Today replaced old FPR with a new one. Only had to disconnect 1 vacuum line, remove two bolts, remove the old fuel hose and then remove the old FPR. I just reinstalled everything back in reverse and when finished it wouldn't start again. Just cranks and cranks. Then just swapped the old one back same thing, crank and crank no start.
I am frustrated and lost, ughhhh
