swaping in a 8.8?????
off_road_junkie21
waterloo ill (back home)
2.9 lt V6
ok i have a 7.5 right now in my truck. i will be swaping in a 8.8. the guy i bought it from said it is from a 96 ranger. will i have to moive the spring pads and will my drive shaft bolt right up? from what i have read in the tech section it is wider then the axle i have now is this tru?
i will be doing this at the same time i repair my spring leafs(one broke on me passager side) i will be using exploader leafs.(ones from a 4 door 4wd)
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
you might need the Yoke for the rear driveshaft and a conversion U joint but otherwise it should be a direct bolt in.
doyouquaxu
26
Orange County CA
the ranger axle is direct bolt on, spring perches are set up for spring over axle.
you're going to have a lot of problems getting the explorer leaves to work right, theyre arched for spring under axle.
snoranger
Professional money waster
ASE Certified Tech
13,627
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
By a lot of problems, you mean that you have to:
- clamp the spring pack together
- remove the center pin
- reinstall the pin the opposite direction
- remove clamps
That should take all of about 5 minutes each spring.
higx6
moreno valley , ca
2.5L
i have a 8.8 i got, anyone know a cheap diff cover? i would like to get a aluminum one but they are pricey!
off_road_junkie21
2.9 lt V6
does anyone have that flang i will need. i dont want to use a conversion u joint(dont trust them) will buy it from them are if they have the part number i will need to get it from ford. thanks shaun
redrangerry97
dubuque
2002
3.0/5.4
if your trying to get rid of a plastic one that never seals, find an 8.8 from an f-150 their at least steel
as far as the drive shaft goes, mine had the companion flange on both axles, so it was a matter of removing 4 bolts, and reinstalling them
