Dmgctrl88
- Apr 27, 2014
- 1
- North GA
- Ford
- Engine Size
- 302
Just a few questions as my swap draws to a close.
1) I have a 1973 C4 from an F100. What size are the transmission cooling fittings? I'd like to run 90 degree fittings and run line along the bottom of the passenger side head, under the harmonic balancer to the two Tranny cooling ports on the 4.0 radiator. (came with two types)
2) I have the oil relocator from Summit.
http://www.summitracing.com/parts/TRD-1028/
http://www.summitracing.com/parts/PRM-2791/
What size/type hydraulic hose and fittings should I use? (I know the summit size says some numbers but I don't quite understand them.
3) My fan clutch fits between the radiator and the water pump alright, I turned down the spacer that came with it, yet the fan still barely touches the top of the radiator (slanted a bit yes). Anyone know of a shorter fan clutch or a way to shorten my foxbody one?
4) I have to figure out shift linkages, specifically the BW1350 shifter. My C5 tail housing is a little shorter than my original A4LD tail housing as the two threaded holes are closer to the transfer case. Anyone ever shorten the A4LD shift linkage or were they ever able to find a replacement?
The transmission is also closer to the front of the truck than the last one so 2 High will be hitting the hump in the floor towards the front of the truck.
