Surprise on 2011 extended-cab 2wd 4.0 drivetrain...
ekrampitzjr
25
Virginia
The Haynes manual and other sources indicate the later extended-cab Rangers all had 2–piece driveshafts with a center bearing. I was under my 2011 last week to change the diff oil and noticed right off (pleasant surprise) that mine has a long single driveshaft from tranny to diff. The center bearing is a royal bear to replace, and I'm glad mine doesn't have it.
The difference might be because the truck has an automatic, not a manual. Or maybe because it's 2wd or because it has the V-6, not the 4, who knows. But I've noticed the 2011 models have some differences from even, say, the 2008–2009s.
This truck had the standard 6' bed, but a 7' bed was available for fleet buyers. Maybe the 2–piece driveshaft came with extended-cabs with that longer bed.
In case you wondered, the diff fluid change went well. The reason for the change was mileage; it was due. I'm running a full-synthetic gear oil now.
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
Dirtman
13,272
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The 2wd automatics all have a one piece driveshaft in 98-2011 :icon_thumby:
ekrampitzjr
25
Virginia
Thanks for the confirmation. Goes to show the aftermarket manuals aren't always accurate, but Haynes has always been held up as the best of the lot.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
4,223
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
My 2011 4.0 SOHC, manual transmission, 4X4 has a single piece, aluminum rear drive shaft.
