Supercharged 3.0L
wjtkb
Hello everyone, Alright to start off yes I know what everyone is going to say so lets get it out of the way, 2.3l turbo, 5.0, just do a motor swap. Even tho I would not mind to do a 5.0 swap or something, I want something a little different. This is not a 4x4 or anything special, just my daily driver. For anyone who has already done this conversion, what were the biggest issues, or hardest to find parts? I found the adapter kit through Morana. I'm looking at the M112 kit, and plan on only running MAX of 5lbs of boost. I plan on upgrading the connecting rod bolts as well as some good head bolts or studs. What should my biggest concern be? I'm open to all thoughts or opinions.
don4331
1,346
Calgary, AB
5.3
OK, start with - M112 is major overkill - its designed for moderate boost (10psi) on a 5.0 Yes, there are kits for it, but that is based more on availability than practicality. At 5psi, you might be losing more power to driving the blower than you are getting back. :(
Better choices for a blower, in ascending order are M90 (T-Bird <3.8>), M62 (Nissan <3.3>) and M45 (Chevrolet Cobalt <2.0>) based on your 5psi limit.
3.slo is notorious for pre-ignition stock; adding boost only accentuates the issue.
Hardest thing on connecting rods is rpms - the pulling down after TDC on intake, so boost is actually easier on them (in theory, you can reduce revs as boost replaces need for high rpm).
I got a long ways into a Nissan 3.3 blower set up when my company closed our prototype shop, so I never finished (getting a 5.0 for $600 didn't help either).
