- Jul 24, 2022
- 44
- Utah
- Mazda B4000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 OHV V6
- 2WD / 4WD
- 4WD
So last night and today are the only 2 times this problem has happened. After sitting for several minutes in gear clutch pedal to the floor the truck stsrts to lurch like the clutch is engaging. I shut of the truck put it in first and while starting it does the same thing then when I give it some revs it went away for the following 20 minutes of driving.
Just finished putting in a brand new motor but i never disconnected the clutch line from the slave.
Flywheel is freshly surfaced
Clutch slave is new as of 6 months ago
Clutch master replaced 6 months ago
Clutch disc and pressure plate also new 6 months ago
Transmission fresh rebuild 6 months ago
