subaru baja wheels
tico0
calif
mazda B2300 SE
Will a set of wheels from a 2006 subaru baja fit my 1996 mazda B2300 SE ?
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Simple answer....NO!!!
Totally different bolt pattern.
Subi is 5x100 mm.
Ford/Mazda is 5 x 4 1/2 or 114.3 mm.
If your looking for wheels that fit, Use the How To Tech in the top header bar. Go to wheels/tires, wheel guide. At the bottom there is a long list of what vehicles have the same bolt pattern,
although the backspacing and offset may be different.
Grumpaw
tico0
calif
mazda B2300 SE
Thank you for your prompt reply, very helpful ,
My truck needs tires NOW (14'' stock) and want to swap to a bigger wheel 15'' or 16'' easier to find tires, more variety than 14''
Saw an ad, 06 ''subaru tires & wheels'' thought I got lucky if compatible with my truck,
Oh well I just have to keep looking !
Again thanks for your fast response.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
Your 14 inch has the same bolt pattern as the Ranger/Mazda 15 inch wheels. Check the wheel/tire guide and look at the common wheels that fit.
Grumpaw
Kirby N.
March Truck of The Month
