- Jun 13, 2010
- 54
- Rochester, NH
- Mix of 78-96
- Ford donors
- Engine Type
- V8
- Engine Size
- 357w
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- 13ish
- Tire Size
- 39.5x15.5
The wheel bearings on my Dana 44 front mangled themselves, had to torch and chisel the inner locknut off, now the inner race on the outer bearing is stuck. Heated it up with the torch, tried cutting it and putting the air hammer to work, still won't budge.
What would you guys try? The 44 is the same bearing setup as a 35. I'm at my wits end on this. Trying to save the hub and rotor, spindles pretty trashed at this point. I do have spares
