Stuck T-case fill plug :(
mr_manny
48
Mexico
235/75R15
Just going through my new to me Bronco II, and came across an uncooperative fill plug :(
Good thing I didn't drain before checking :)
Any tips on getting this sucker loose?
Thanks
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
15,770
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Dissimilar metals corrode together. I would start by soaking it down with penetrant. Tap it a few times with a small ball pien hammer... try to loosen. Repeat...
alwaysFlOoReD
5,932
Airdrie, Alberta, Canada
’97, '06
Pontiac, Dodge
2.2,5.7
If you can get a hammer swing in there... Use a cold chisel on the outer face and start tapping fairly hard. Eventually it will start to move.
alwaysFlOoReD
5,932
’97, '06
Pontiac, Dodge
2.2,5.7
mr_manny
48
Mexico
235/75R15
What a pain in the A**
Tried the bolt method, mentioned in the video above.
Fill plug was not letting go, only ended up deforming further.
I ended up drilling a hole, and tried removing the fill plug via an ez-out...no luck.
Since I already had a hole, I taped it and now have a new fill bolt :)
So glad this is done...just in time to cook dinner :p
SenorNoob
1,346
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Nice. There is usually another way.
Jazzer
611
Indianapolis
Might want to file that boss flatter and don't forget a crush washer.
Nice thinking outside the box!
mr_manny
48
Mexico
235/75R15
All ready using a crush washer, but good idea on prepping the surface to be more bolt/washer friendly.
Game plan is to eventually replace the Differentials, Trans, and tcase from an explorer down the road.
Already got the green light from the wife :)
Wallows in rivers
21,457
SW Iowa
They actually make a socket that fits that hole better than a socket extension too, it can really help prevent deformation if they want to be ornery.
mr_manny
48
Mexico
235/75R15
I was surprised how stuck the fill plug was...just did not want to budge.
I tried:
Large Steel Bolt, profiled to fit the plug tightly.
Chisel & BFH.
Heat around around the fill-plug.
Vice Grips, unfortunately not enough shoulder to bite onto.
Drilled hole for ez-out.
Didn't want to risk breaking it, but a larger ez-out might have worked (largest I own is around 5/16th).
Even though I wasn't able to get the fill plug out, I'm pleased with the solution.
Wallows in rivers
21,457
SW Iowa
I tried:
Chisel & BFH.
Just food for thought next time one fights ya, I deal with a lot of old plugs and the regular socket really helps.
Once you start to waller out the hole it goes downhill quick.
scotts90ranger
5,780
Dayton Oregon
2.3 Turbo
Before you get too crazy swapping parts do you know if you have a 1350 or 1354 T case now? The easy way to tell is if the front driveline is one piece and the slip spline is at the front of the transfer case, '90 is a split year with some having the more desired 1354 and others with the older 1350... same with the front diff, if the pumpkin has 12 bolts it's a Dana 28 and 10 bolts it's a Dana 35...
I'm pretty sure you tried too hard before you added heat, like 85 said it goes downhill fast with those, the on on the rear axle of my F350 is completely screwed but I can fill it through the speed sensor hole that and last time I was in there I added a fill plug to the diff cover...
mr_manny
48
Mexico
235/75R15
Your probably right, regarding going to hard initially...
Front drive shaft is a slip spline at the tcase.
Good info. on the 28 vs 35, will check when I get back.
Thanks for the Tip.
scotts90ranger
5,780
Dayton Oregon
2.3 Turbo
If you have a slip spline at the T case then you will have a D28 unless someone swapped it before you...
Swapping the T case and front axle can start a worm hole on a 2.9L powered RBV since they used so many dang transmissions which were almost all different lengths which changed the front driveline length... that said if you happen to have one of the unicorn early ones with an M5OD the front driveline from a '91-94 explorer or later TTB ranger with a 1354 and D35 will work... The D35 needs an inch shorter front driveline so worst case you can get one shortened...
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
