Stranded need help
azrangerman85
14
arizona
ranger xlt 4wd
My 3.0 has carbon emission smoke coming through the air intake and out the hose . I stalled really bad. I disconnected my air intake big hose and opened the butterfly throttle valve and see emission smoke coming out . Just a little but my engine is choking on it . I need help! I havent changed my egr valve yet but the diaphram works . Im confused ! whats causing this and how can I get going ? emergency advice needed
franklin2
1,758
Virginia
Smoke coming out when you turn the engine off is normal. That is why you have to clean the throttle body every few years. That smoke builds up and coats everything in the intake.
Trump8MyKids
37
Fond du Lac, Wisconsin
Just a shot in the dark but you maybe lost compression? The exhaust/fuel might be leaking past the rings and into the oil pan which then vented through the line that goes from the oil fill tube to the intake tube (I forgot the name of it). But as Franklin said could just be the throttle body. If it isn’t the throttle body you may have a problem the size of trumps ego 😂
azrangerman85
14
arizona
ranger xlt 4wd
biden harris communism just entered my truck like the demons
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Have you tried cursing at it?
