Stock Cab Bushing Size
budmc77
Hey guy,
I'm running a 97 ext cab and am in the process of replacing all my cab bushings. Does anyone have the stock dimensions of the the bushings around the truck? My existing onea are pretty chewed up and from what I can tell the back two are right at 2 inches whereas the front and the radiator support ones are one inch. I am talking about the ones between the frame and the cab too. I plan to put just a 1 inch body lift on it but don't want the cab to be higher or lower in one section than other. My bushings will be made with a rubber compound that we use at work but just need to cut to size. Or if anyone has the sizes from other body lifts such as a 2 or 3, I could take how long they are and just subtract the "lift" from those dimensions. Thanks!
Sent from my SAMSUNG-SM-G900A using Tapatalk
