Stepside/Flareside options
aknott1994
4
Michigan
I have a 1992 Ranger and my bed is shot. I want to put a classic Flareside type bed on it, what would be the closest option anyone can think of?
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
ericbphoto
Old Redneck just wingin' it.
Forum Moderator
2,706
Wellford, SC
6"
Get one out of the junk yard or off Craiglsit and bolt it on. I'm pretty sure you'll need a different filler neck. But if yours is original, it will need replacement soon anyway.
Well-known member
1,808
+1 ^^^
I think 1994 was the first year Flareside/step side was offered on Rangers
The 1994-1999 Flareside will bolt in and have the same tail light wiring, 2000 and up will work but you will need the tail lights from 1993-1999, or a 3 wire to 2 wire converter
The 1993 and up Rangers were about 2" wider than 1992 and older, but not sure that would be noticed on flareside as much as styleside(regular)
The frame was the same, just body got wider
aknott1994
4
Michigan
I am not looking for a Ranger bed. I want a classic style bed to put on my truck from the 50's or 60's, maybe 40's. I can fabricate for the mounts. I am more asking about widths and lengths I guess
Well-known member
1,808
Have a look here: https://www.therangerstation.com/tech/ford-ranger-dimensions/
You have a 1st gen, 1983 to 1992
All Rangers have a 6ft bed, regular or super cab are the same, as are style or step side lengths
There were Long Bed Rangers, styleside only, and regular cab only with 7ft beds, but used a different frame, the rear axle was 6" farther back, so the long "beds" don't fit on standard bed Rangers, there's a 6" gap between cab and bed, when wheel wells are lined up
Width will obviously be an issue, but step sides are narrower
Other issue will be wheel well from center to cab, or it will look goofy
No, I don't know of a non-modified bed from another model that would fit a Ranger
Ranger850
Well-known member
1,245
Tallahassee Florida
Stock 2"
Stock
Are you talking about the shadowbox style?
41910
aknott1994
4
Michigan
Yes, like one of these beds on a Ranger
ericbphoto
Forum Moderator
2,706
Wellford, SC
6"
Ranger850
Well-known member
1,245
Tallahassee Florida
Stock 2"
Stock
A guy over at InfamousNissan.com used one of those beds on his hard body. I didn't like it but it turned out ok
41933
He has since painted it lime green with black accents. You'll notice the 5 lug swap and I believe it also has an LS motor swap
