Steering Wheel Vibrations
scottp
I have a 2001 Ranger with 58K miles. Lately I have been noticing some vibrations in the steering wheel at certain speeds. Its almost as if the tires are out of balance. I had the tires balanced and rotated about a month ago. I also had the tires rebalanced just a couple of weeks ago, so I do not think its a balance problem. I also assumed that the tire places checked the tires for knots or bent wheels when doing the balancing, so I don't think its something like that. I did notice some vibrations before I had the tires balanced and rotated, I kind of think it has gotten worse since I had them balanced and rotated.
I notice the vibrations between 50MPH and 55MPH. I don't always notice it, and sometimes its worse than others. Sometimes I can take my hand off of the steering wheel and see the steering wheel vibrating up and down. I'm not a mechanic and don't have a lot of knowledge when it comes to diagnosing vehicle problems like this. I'm really at a loss as to what the problem might be. I've heard that 2001 Rangers have problems with the ball joints wearing out. Would this cause vibrations like this? Any other suggestions? I will probably end up taking it to a mechanic anyway, but I was just looking for something that could possibly be the problem.
Thanks
Cobrablues
18
Placitas, New Mexico
Lariat
I have A 2020 Ranger with 4000 miles and it does the same thing at around 75 - 80. It was doing it at lower speeds but having them balanced for the 2nd time helped. It is irritating. I have 33x12.5x 20 inch wheel/tire setup with 4 inch lift. I had an FJ Cruiser with the same tires but smaller rims and never had this problem. I may just go back to a independent tire company and see if the have ideas.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
It took 13 years for this guy to get a response? Shame... Shame on all of you...
This is not the TRS I know and love...
ericbphoto
Overlander in development
16,584
Wellford, SC
6"
I wasn’t on here 13 years ago. Don’t blame me. I haven’t read all the old threads. Ain’t nobody got time fo dat.
sgtsandman
Aircraft Fuel Tank Diver
12,633
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It could be a problem with a tire itself than a balancing issue. I would go back to where you got them and have them sort it out. It might be a manufacturing defect.
Cobrablues
18
Lariat
Hmmmm. The date says 13 years ago but the post is about a 2021 Ranger. I am not a mathematician but I did know a constipated one that worked it out with a pencil.
Paulos
210
North Carolina
1987 STX
Hmm... 2001 twice in the OP's post. No 2021 that I can see. I'm not a mortician either, but if I was and my customer was constipated, I don't think he'd care. A pencil would hurt :confused:. Oh, "mathematician". Never mind.
ericbphoto
16,584
Wellford, SC
6"
It's OK. We like to tease once in a while.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Mathematicians or Morticians with Pencils, both sound a bit perverted.
In any case, rotate the tires & see if the vibration move\changes.
600$04Ranger
44
Ashland, OR.
Xlt 4wd 4.0L V6
31x10.5
Mandates are for fascist dictators!
I was thinking "how the .... did you get a 20 year old ranger with only 58,000 on it?! Even if it took 13 years to answer it's still helpful to read the responses for those seeking answers to similar issues. Maybe there could be a section for threads where the original poster reports how they ended up fixing/solving the situation?
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I had a very similar situation on my truck. I would get a vibration at just over 70mph and was gone 76mph and above.
My advice is to really tune into the vibration... and determine at what corner you believe the vibration is coming from. Once you determined what corner it's coming from.... rotate that tire with another. See if the vibrations moves to where you think it should have. Then focus your efforts on that tire/wheel.
When I did that I noticed there was one singular large wheel weight on that wheel. I went to the tire store and had them rotate the tire on the wheel 180 degrees and rebalance. The amount of weight needed was reduced by about half and the vibration disappeared.
Both the wheel and the tire will have a heavy spot that just happens during manufacturing. When those two heavy spots align during installation... a larger amount of weight will be required to offset the imbalance. In my experience... it will cause issues.
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
We try to encourage all the "please help me fix this problem" threads to post a resolution to their problem... it is impossible to keep track of it or make anyone report the fix. Let alone create an individual forum for resolved issues.
The current format is pretty much the best we can do.
Just remember... a bunch of the information that is collected and found on TRS... comes from the valued membership of people such as yourself. So just keep the information coming and keep TRS the great resource that it is.
Cobrablues
18
Lariat
Oaky, my bad....bad eyes I guess. They do deceive me.
sgtsandman
12,633
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
In any case. Take the suggestion about rotating the suspected tire with the other and see if the vibration moves or stops. In either case, you have narrowed down to the offending wheel and can get the issue looked at by the shop that installed your tires.
600$04Ranger
44
Ashland, OR.
Xlt 4wd 4.0L V6
31x10.5
[/QUOTE]
Absolutely! I have been coming here for knowledge since my first Ranger 5 years ago. I'm working on a write-up about my experience rebuilding my current Ranger which I bought for $600 on Craigslist. A year later after pulling the motor 4 time's, nearly giving up on it before spending way more money than my over optimistic initial estimate and I finally have a fairly decent 4x4. I made so many mistakes and misdiagnosed major issues that turned days into weeks and weeks into even more knuckle busting, head bashing sessions that destroyed any delusions I had that I was gonna make quick work of a truck that had seen many miles of neglect before I got it home. Any suggestions on how to make it an enjoyable and informative read would be welcome.
