Crashtest84
- Sep 6, 2007
- 0
- Tulsa, Ok
- ford
- Engine Size
- 4.0
In the middle of my engine swap my A.D.D. kicked in and I started messing with the gear box and steering shaft. I found 90% of the slop/slack to be in the slip part between the rag joint and u-joint "89 ranger 4x4" So I pulled the whole shaft out to see whats loose. After pulling it apart I found tension spring if you want to call it that was broke "see pics" I haven't been to the parts warehouse to see if I can get just that part. In hopes I can I will update and let tell if it tightens things up.
