89Rager
- Jun 8, 2018
- 0
- Ford
My 1989 Ford Ranger 4wd manual has a problem with the steering. When going down the road it would pull to the right but if you had to make a left turn it will jerk to the left once it reaches a certain point. I jacked the front end off the ground looking for bad bushings in the front end but found none. With it still jacked up I turned the steering wheel and you could feel it. So I disconnected the steering linkage below the steering box. The steering box is smooth. Then I disconnected the tie rod linkage on the drivers side. The passenger side turns free but the drivers side does not. When you try and turn the drivers wheel by hand it locks up in the center. When it locks up and you jerk it free the front driveshaft moves even though the manual locking hubs are unlocked.
I don't think its the ball joints, I'm leaning towards front u joint. Is there something I am overlooking? Can a bad u joint cause the steering problem?
