Dprocks100
- Jun 3, 2013
- 0
- Salt Lake Utah
- Ford
- Engine Size
- 2.3
Last friday my truck started steaming and loosing a lot of water through the tailpipe. Sucked 3/4 of my coolant out of my overflow tank in a 20 minuet drive. Its got 143,xxx miles. It burns about a quart every 3-4,000 miles. Did a compression test and got 120-115 psi over all 4 cylinders. my haynes manual says that it should be 101 psi minimum but says nothing about whats considered good. What should it be? When I had the test all cylinders steadily climbed to their max in about 4 seconds. Am I right to assume its my head gasket? or is it more likely my head or block? There is no water in my oil. And the truck seems to run fine other than the excessive amount of steam and water out the back and a little less power.
If the engine is destroyed it will just move my 4.0 swap that much sooner.
